Телескопы покупают здесь
A A A A Автор Тема: Восход солнца ,за полярным кругом(в гренландии )  (Прочитано 4087 раз)
Оффлайн gamewalkerАвтор темы
  • Вселенная? Космос? Мегапарсеки? - Полноте: пустое!
    • Сообщения от gamewalker
Восход солнца ,за полярным кругом(в гренландии ) в этом году произойдет на два дня раньше ,чем положено по астрономии .С чего бы это ???
http://hisz.rsoe.hu/alertmap/woalert_read.php?cid=29183
Beyond the Arctic Circle, can find the time needed for day and night depending on latitude up to half a year, the sunrise something very special - even more so when the always joyfully anticipated event is just around two days early is taking place. According to the KNR Radio Greenland, the sun was in West Greenland Ilulissat on Tuesday (11.1.) at exactly 12:56:57 Clock. Normally the sun goes there until 13 January for the first time after the polar night again. Inhabitants of the third-largest city with 4,500 inhabitants of Greenland, made because of the early sun appeared worried. "Here in the place the sun comes up until 13 January. There will not be the right one or the other," quoted the Greenlandic radio KNR Holger Sivertsen, a 74-year-old local, in a report on his website. Scientists rule out that the observation could have geophysical or astronomical reasons. "In the constellation of the stars has not changed, "said Wolfgang Lenhardt, head of the geophysics department at the Central Institute for Meteorology and Geodynamics (ZAMG) on the high tower. "Since even an outcry would have gone around the world." The data of Earth's axis and Earth's rotation in question were constantly and meticulously monitored. Thomas Posch from the Institute for Astronomy at the University of Vienna completed astronomical reasons for the premature end of the polar night also made. He suggests that the observation is due to a change in the local horizon. An accelerated by the melting of the Greenland ice sheet-related lower horizon earlier than previously allowed a glimpse of the sun appears, as "by far the most obvious"explanation. According to Lenhardt it could possibly also to an atmospheric phenomenon - act - for example by ice crystals caused a mirage.
Oreon 127 MAK + Meade LDX 55 Autostar + Webcam Philips
Оффлайн Okub62
  • Благодарностей: 601
    • Сообщения от Okub62
Гора льда стаяла, за которой раньше Солнца не видно было.  :)
С уважением. Олег
Оффлайн Женек
  • Женек
    • Сообщения от Женек
Во-первых наша планета движется неравномерно вокруг своей оси и из-за этого даже точки солнцестояний и равноденствий могут смещаться на 1 день вперед или назад.
Во-вторых щас нас календарь примерно на 0.75 суток вперед только в следующем высокосном году выровнимся (в году 365.2422 дня но в календаре 365 дней или 366 дней. За три года разница ошибки составила 0.2422 х 3  примерно 0.75 суток но эта ошибка ликвидируется в следующем году который будет высокосным).
делаем выводы - вращение Земли и наш календарь из-за этого как раз и может быть разница наступления полярного дня
taurus
Смещение равноденствий и солнцестояний на день вперед или назад происходит не из-за "неравномерного движения нашей планты во круг оси", а из-за четырехлетнего високосного цикла.
А как вам такая новость.
Гренландское чудо пока не имеет научных объяснений
   06:12
Город Ллулиссат, во всех отношениях могущий претендовать на скучнейшее место на планете, прославился феноменом преждевременного восхода солнца. Утро наступило на два дня раньше положенного срока (после полярной ночи).
Некоторый фурор среди ученого сообщества вызвало самое обычное событие: наступило утро. Проблема в том, что утро наступило в Ллулиссате (датск. Якобсхавн), гренландском городке с численностью населения в 4500 жителей, который находится за полярным кругом. И наступило на двое суток ранее положенного. Объяснений этому явлению пока не найдено и в ученом мире распространяются нелепые объяснения, почти столь же нелепые, как и в таблоидах про инопланетян и конец света.
Итак, жители Ллуллисата увидели восход солнца 11 января. Согласно сообщениям прессы, солнце не должно было появится ранее, чем 13 января. Прежде всего следует сверить данные с астрономическими таблицами. Вот таблица закатов и восходов для координаты W051 06, N69 13:
Как видим из таблицы, которую любезно предоставил ВМФ США на сайте Astronomical Applications Department, действительно гренландским чукчам в чумах рассвета ждать не приходилось и солнце застало северян врасплох. Вместе с тем достаточно надежные источники подтверждают появление солнца за двое суток до положенного срока – 11 января.
Что же заставило солнце взойти ранее срока? Научные объяснения, которые циркулируют в сообществе отличаются от желтой прессы только наукообразным языком, но не достоверностью.
Есть гипотеза, что необычная рефракция вызвала иллюзию восхода солнца. Тем не менее восход солнца – явление достаточно точное, и ошибиться на два дня оно точно не может даже в Гренландии. Ошибки такого рода неизвестны науке. Характерно и другое – «иллюзия» повторилась и в другой день – 12 января. Столь долгое существование аномальных рефракционных линз невозможно.
Другая, еще более нелепая гипотеза выдвинута поклонниками глобального потепления. Льды Арктики, дескать, настолько растаяли, что опустилась линия горизонта. Не смотря на то, что гипотезу выдвинул какой-то именитый эколог мы позволим себе назвать ее несусветной чушью. Насколько должны были растаять льды, чтобы опустился горизонт? Может просто планета уменьшилась.
Интересно, что данные о восходах солнца в других полярных регионах самые заурядные и не зафиксировали аномалии.
На фоне молчании науки поползли слухи о конце света. По крайней мере они заполняют долгие полярные ночи, которые все еще продолжаются в Ллулиссате.
globalist.org.ua
VBR
Двое суток аномальной рефракции? Да никаких проблем.
Оффлайн Basenko
    • Сообщения от Basenko
Это событие поставило учёных в тупик:одни говорят,что меняется угол наклона земной оси,другие обьясняют это атмосферными явлениями,третьи-началом апокалипсиса предсказанного на 2012 год...и ни одного правильного(научно обоснованного)ответа.    Однако,всё это обьясняется очень просто в свете научно обоснованного доказательства закономерности солнечной активности,,которое за всю свою трудовую жизнь,построил В.И.Басенко и опубликовал в своей книге,,Космическая сенсация"(2009год).Его открытие основано на том,что все мы видим только атмосферный покров солнца и упорно не хотим видеть его осново составляющий шар,который скрыт под фотосферой и который имеет свою ось вращения,свой период вращения,свой наклон оси вращения и свои дипольные магнитные полушария,магнитосфера которого и является основной причиной источника света и всех циклов солнечной активности.
Оффлайн SWN
  • Благодарностей: 109
    • Skype - Astrowlad
    • Сообщения от SWN
    Может особенно ничего сенсационного и нет?
   Из статьи о рефракции.
Горизонтальная Р. подвержена большим аномалиям особенно в холодных странах. Как пример этого можно упомянуть наблюдете Барентца. (голландская экспедиция, зимовавшая в 1597 г. на Новой Земле под 76° северной широты), Он увидел после полярной ночи солнце уже 24 января, т. е. на 17 дней раньше, чем ожидал, - Р. достигала 4°. Помимо неполной шарообразности земли, слои воздуха равной плотности не всегда расположены параллельно поверхности земли; вследствие этого происходит так наз. боковая Р. - изменение азимута.
http://www.wikiznanie.ru/ru-wz/index.php/%D0%A0%D0%B5%D1%84%D1%80%D0%B0%D0%BA%D1%86%D0%B8%D1%8F
Оффлайн CADET
  • Благодарностей: 374
    • Сообщения от CADET
    • САМИЗДАТ
Поскольку никто тогда не ожидал никакой Нибиру, этот казус просто приняли к сведению.
МОЯ ФАНТАСТИКА И ФЭНТЕЗИ
Маринер-9
Горизонтальная Р. подвержена большим аномалиям особенно в холодных странах. Как пример этого можно упомянуть наблюдете Барентца. (голландская экспедиция, зимовавшая в 1597 г. на Новой Земле под 76° северной широты), Он увидел после полярной ночи солнце уже 24 января, т. е. на 17 дней раньше, чем ожидал, - Р. достигала 4°. .
 Кстати, из-за этого явления (Р) светлые летние ночи в умеренных широтах могут наступать раньше расчётных - а ведь можно понаблюдать, не правда ли?
Оффлайн SWN
    • Skype - Astrowlad
    • Сообщения от SWN
   И как это связано с темой? ???
  Что же это за ученые такие? :)
Он  всегда рассказывает ее в третьем лице, делая вид, будто он так  скромен,  что  не хочет прославлять самого себя.
   М.Твен "Янки из Коннектикута при дворе короля Артура".
Оффлайн CADET
    • САМИЗДАТ
Никак. Просто г. Басенко намекает, что стоит кому-нибудь любопытному заикнуться: "А..?" как тут же прозвучит полное изложение его гипотезы.
Оффлайн SWN
    • Skype - Astrowlad
    • Сообщения от SWN
   Вполне вероятно! :)
    А может и нет. В статье речь шла о холодных странах. К тому же наблюдалось это в январе.
Маринер-9
  Там солнце восходит в январе – феврале. Но аномальная рефракция может проявиться в любое время. Можно или мерить яркость сумерек в расчётное время (например, для положения Солнца 10° под горизонтом), или отмечать время появления яркой звезды (тут могут быть плюсы-минусы, но на большом массиве данных они исчезнут). К тому же наблюдения крайне просты
Оффлайн SWN
    • Skype - Astrowlad
    • Сообщения от SWN
  Вы как в воду глядели! :)
Вот что мне пришло сегодня по почте
Получить информацию по приобретению книги В.И.Басенко КОСМИЧЕСКАЯ СЕНСАЦИЯ,можно по тел.:х-хххххххххххх
:o
Оффлайн CADET
    • САМИЗДАТ
...Тут же прозвучит изложение его гипотезы... За деньги!  :D
Оффлайн petrovich1964
  • Благодарностей: 205
    • Сообщения от petrovich1964
не в тему, но ...
Когда на Северном полюсе полдень?
Оффлайн CADET
    • САМИЗДАТ
Сначала нужно договориться о терминах. Что такое полдень? Если это момент времени суток, когда Солнце находится точно на юге, то полдень на СП всегда, поскольку там все направления южные. Если нечто другое, то нужно это оговорить.
Оффлайн Dem
  • Благодарностей: 134
  • Звёзды зовут...
    • Сообщения от Dem
Изначально полдень - половина дня. Т.е. середина по времени между восходом и закатом.
А нахождение на юге и максимальная высота над горизонтом - более поздние толкования.
Оффлайн CADET
    • САМИЗДАТ
Если полдень, это половина дня, то этот момент наступает на СП в момент летнего солнцестояния. Кстати, при этом и солнце находится на юге :) и имеет максимальную высоту над горизонтом.
